cruise control not working
just wondering if anyone had this problem or anything before. i was driving on a 30 mph road and i set my cruise at around 30 but i saw a cop so i slowed down to 25 just to be safe and my cruise control completly cut off and now it wont turn on again? as soon as it hit 25 witch i guess is the mark for it to start working i checked the fuse and changed it out but that wasnt it any sugestions? im about to drive 1300 miles next week and id rather not push the pedal the whole time cause then i tend to speed a bit more.
IRRC cruise control won't work at 25 or under, that's just how the system is designed. It should continue working once you accelerate above 25. Was this during the same drive? You might need to turn your ignition off. For some reason my cruise control did that one day: it just wouldn't engage no matter what speed i went. The next day it was fine though.
no i mean it hasnt worked since and that was 4 months ago it wont work at 60 mph 50 or anything ive tried tried at 26 and 30 to it just wont kick on it all. it was just as soon as i dropped to 25 it stopped normally but wouldnt come on again it just dosent want to engage it dosent even try.
yea i push it over to on then press the button on the side and push it all the way over thats how the cruise control worked before for me lol im thinking it might be that whole switch peice maybe something came loose inside.
You could check the wires for voltage. A couple things will prevent the CCM from engaging. If it's not getting the "on" signal (obviously), it's not getting power, a signal from the clutch switch or brake switch, or a faulty signal from the VSS somehow. I suggest you check the wiring and make sure that the proper signals are being sent to the CCM.
