Monsoon sticky faq TYPO?
I am trying to figure out which wires are the rear sub input for the amp so I can tap them for an aftermarket amp. I have been reading the chart posted in the monsoon faq sticky thread and it lists the output for the rear subs in the firebird coupe section twice but does not reference the input for the subs to the factory amp. Anyone know which is which?
Ungrounded Moderator
There is no "sub" input to the Monsoon amp. The head unit provides four-channel speaker-level output just like any other Delco radio and the amp uses that as input. Unless you bought an aftermarket amp that accepts speaker-level input, you will need a LOC to convert the signal to pre-amp level for your amp. You will also need a low-pass filter if your amp doesn't handle that.
The output from the factory amp to the subs is listed twice because the subs are dual voice coil so they each have two positives and two negatives.
OK last question. If I use the left and right rear input will I still be able to keep my rear speakers functional? If so do I just tap those wires and leave them connected to the stock amp? Thanks in advance!
