Can we install the yella tera 1.8 rockers on the 305 LXR heads ?
Hi Guys!
Just one question , I'm running 12:01CR LSX454 , Heads are LS7 MAST 305 , LS7 stainless steel shaft mounted rocker
arms 1.8 ratio , cam with 1.8 rockers 254/262 660/660 112 , My rockers are adjustable so I should adjust them all time so I really did'nt like them.
what I need is an non-adjustable rockers
My question is...
Will the 1.8 yella tera be fit on my heads ?
Or lets suppose that you built 454LSX with those heads what rockers do you prefere to run ? and what cam ?
Waitin' for you'r feedback!
My question is...
Hydraulic= Yella Terra. Why wouldn't they fit on your heads regardless? You will most likely have to do some valve cover modifications though for clearance, but that should be about all.
Thanks all
well we have the Crowe adjustable rockers
we have some problem on adjusting them as there is some noise on the rockers
there are more than an 100rwhp drop from those rockers.
from what I know is that the Crower rocker are one of the best rockers on market but I don't know what happened.
