How to replace turn signal wiring harness?
Old 06-27-2011, 08:58 AM
jstevanus's Avatar
Question How to replace turn signal wiring harness?
My right turn signal is out, and the mechanic told me that the wiring harness was completely coroded, green, and needs to be replaced. I found one online for $20. Is this something I can do myself?
http://www.gmpartsgiant.com/parts/gm...-10351972.html
Old 06-27-2011, 11:39 AM
mike690003's Avatar
I might have one of the harnesses. Let me go check in the garage.
Edit: Just checked, I have one. You only need to cut 3 wires to splice in the new harness. Super easy!
Old 06-27-2011, 11:57 AM
jstevanus's Avatar
How exactly do I get to it? I thought I read somewhere that I have to remove the headlight first?
jstevanus's Avatar
This is for a Grand Prix GXP BTW. I should have noted that in my first post!
Old 06-27-2011, 12:09 PM
texasGXP08's Avatar
Remove the headlight then just look down.
Old 06-27-2011, 01:38 PM
mike690003's Avatar
Oh, I have am Impala/Monte one..Don't know if they are the same though.
Old 06-27-2011, 02:17 PM
jstevanus's Avatar
Thanks! I'll open it up and check it out. Hopefully I don't have to cut/solder wires!
Quick Reply: How to replace turn signal wiring harness?
