Lunati voodoo cammed 383 60121 vs 60122
Hey everybody, I recently blew up my cam only LT1 with Lunati voodoo 60121 cam and am planning on getting a shortblock with forged 383 internals and it comes with a Lunati voodoo 60122. My question is how driveable would a 383 be with the bigger 60122 cam vs the baby 60121? It was great with the 60121 (car is 6sp with 4.10 gears). I'm planning on getting the 190cc Ai ported heads package and already have a ported intake with 52mm TB. Do you think this cam is tame enough for daily driving duties with 383 cubes and 4.10's (98% street car)? I know the smaller 60121 would be a torque monster and be like stock driveability but cost a little up top. Let me know your thoughts on this because I will have both cams to pick from. What sort of HP should I expect with these two cams?
Part Number: 60121
Hydraulic roller, fair idle. Strong power increase in mildly modified engines with excellent throttle response. Will work with stock converter in 383 and up size engines or 2200 RPM stall speed converter in 305-350 cubic inch engines. Likes 3.23-3.73 rear gears. Also the largest cam for inboard/outboard marine applications.
Advertised Duration (Int/Exh): 270/278
Duration @ .050 (Int/Exh): 221/229
Gross Valve Lift (Int/Exh): .515/.530
LSA/ICL: 112/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-5800
Includes: Cam Only
Part Number: 60122
Hydraulic roller, lopey idle. Great street machine cam! Likes upgraded intake carburetor and exhaust. Needs 9.5:1 or better compression and 2500 RPM stall speed converter and a 3.42 or better rear gear ratio.
Advertised Duration (Int/Exh): 282/290
Duration @ .050 (Int/Exh): 231/239
Gross Valve Lift (Int/Exh): .535/.550
LSA/ICL: 110/106
RPM Range: 2400-6200
Includes: Cam Only
Part Number: 60121
LSA/ICL: 112/106
Includes: Cam Only
Part Number: 60122
LSA/ICL: 110/106
Includes: Cam Only
Just went through this with my 95. Talked to Lunati about my set up and they suggested the 60122. My set up is 4.30 gears, 3500 stall, stock short block, ported stock heads.
BTW: Be sure you specify the year when you order the cam. Mine came with a short pin and I had to replace it to drive the Optispark.
Al 95 Z28 still apart but getting there. Primed the oil pump and set the valves today. Just about to check push rod length.
I already have the matched valvetrain for the lunati cams with their expensive *** beehive pacaloy springs...plus I already have 2 cams now; no need to spend even more money on a third cam for minimal (if any) gains over an Ai grind cam. I'm sure the Ai heads will make just as good power with a lunati voodoo vs their cams....the specs are very close with the 2 lunati grinds vs. similar Ai grinds:
Lun 221/229 - .515/.530 -112 LSA
Lun 231/239 - .535/.550 -110 LSA
Ai 218 / 226 - .540/.540* - 112 LSA
Ai 230 / 238 - .575/.575* - 110 LSA *based on 1.6 rocker
I highly doubt there is a significant advantage to running a "matching" Ai cam as long as you don't pick some oddball cam choice.
a stock 350 lt1 (with bolt ons) can run and be a DD on a 230/244 cc306. A 383 with ported heads would have zero issues with the lunati 231/238. you could even go with that larger A/I cam the 234/242 and be fine.
This isn't really related to my cam comparison I started the thread about, but I'll ask anyway instead of making a new thread.
What does everybody recommend for my Ai stock ported heads for a street 383; the 190cc or the 200cc version?
http://advancedinduction.com/LTX/AiLTxCylinderHeads.php
I'm probably going with the bigger 60122 cam and already have a ported intake FYI.
I successfully street drive a bigger cam then the 60122 on a 350. It's not that bad if its tune appropriately. I have a 232/241 on a stock shortblock lt1. It helps my car is a six speed but with the right stall I would glady run mine through an automatic.
So nobody has any recommendations on which Ai head package? I emailed Ai to get a quote on both while re-using my lunati beehive springs and they quoted me:
200cc Dominator LT1 CNC Head (customer supplied springs & components)
CNC'ed Intake Port,Exhaust Port,& Chamber
CNC'ed F1 Quality Competition Multi-Angled Valve Job
Machine Intake/Exhaust Flanges & Valve Cover Rails To Ensure Proper Port Alignment & Sealing
Deck is PCD Milled For Superior Surface Finish, Flatness, and Desired Chamber Volume (52cc - 57cc)
Completely Hand De-burred To Remove All Sharp Edges
Hydrostatically Pressure Tested & Hardness Checked to Ensure the Casting's Integrity
Custom Manley Pro-Flo Severe Duty Stainless Valves 2.00 Int/1.56Exh w/Hi-Performance Metal Clad
Viton Valve Seals
1 1,300.00
For 190cc machining with valves & your springs and components $1,150.00
What do yall think? Is it worth an extra $150 for 200cc heads? Ai said the 190cc would meet my goals no problem.
Viton Valve Seals
1 1,300.00
1 Post
I feel that the 200cc heads are the way to go. I wish my high school budget allowed me to get them, but Im stuck with the local shop here (which still isnt too bad)
