99 z28 new start still no spark
Old 06-28-2011, 09:15 AM
nicholerp22's Avatar
Default 99 z28 new start still no spark
i have a 99 z28 just replaced starter due to the old one being bad. got new one on when key is turned it turns but no spark. any ideas ? battery and everything checks out good no codes are showing
Old 06-28-2011, 10:05 AM
jam01's Avatar
did you test for no spark or are you assuming? check fuel pressure and air filter are some other easy to check symptoms. maybe crank or cam sensor loose connections or burned wire.
Old 06-28-2011, 06:50 PM
everything tested out good no burned wires sensors are good and getting fuel still nothing
Old 06-29-2011, 05:30 PM
jam01's Avatar
pull a spark plug wire off and plug ground it have some one crank your engine over and see if you get a spark.
Old 12-20-2011, 03:32 PM
SSV1761982's Avatar
I wonder what the answer was?
