Wiring Issues
Wiring Issues
So I've had my 02 WS6 about 9 months now, and after lowering it the alignment went to crap; the O2 sensors went bad and the viper alarm goes insane on its own.
Now the ABS inop/TCS OFF lights have come on.
Any suggestions as to where I need to start looking if its a wiring problem or if the bad tires and alignment are causing this?
Thanks!
Thanks!
Best place to start would be the areas you were working in. Maybe someone somehow pinched some wires. Especially the ABS and TCS lights b/c both of those systems are controlled by monitoring the wheel speed sensors on each hub. Seems like a wire got either pinched or torn apart. Just do a very close inspection and see what you can turn up.
