Lets play a game....** now with more carnage! yay
Old 07-02-2011, 06:21 PM
jt76's Avatar
Default Lets play a game....** now with more carnage! yay
What is the object to the left in this picture?
The round is a 30-40 krag (similar in size to a 30-06) used to scale the object... GO!
Old 07-02-2011, 06:32 PM
TankTheTurtle's Avatar
looks like a dried up blueberry to me
Old 07-02-2011, 07:30 PM
jt76's Avatar
ok well no one wants to play so i guess i will go into further detail...
I installed a new Spec 3 clutch last fall ~3,000 miles ago. I did not go to the track, do burnouts, spray nitrous or anything. I have a heads/cam setup making ~450rwhp. Whatever this thing is, it came loose from somewhere and did some damage which i will show below. It is NOT a bolt. I took it to my friends performance shop after i did a 2nd gear pull and started hearing God awful noises and the pedal feel is all over the place. He pulled off my starter and with a magnet pulled this thing out. He thinks its a weight off of the pressure plate? I would just like to see if anyone knows what this thing is or has had a similar thing happen before i look for my next course of action.
Here are some pics:
My bell housing is destroyed, it has actual holes in it that look like someone shot it with a .22 rifle as well as numerous cracks. My starter is also chewed up pretty well.
FML
Old 07-02-2011, 07:39 PM
dtsti's Avatar
That looks pretty bad but I dont see why you cannot continue to use that housing.
Old 07-02-2011, 07:41 PM
jt76's Avatar
Structural integrity? the one crack is ~5" long
Old 07-02-2011, 07:46 PM
dtsti's Avatar
Of course it is a gamble. When I reinstalled my t56 back in RX7 we broke a piece off the bell housing that made 2 bolts useless. I rolled the dice and went with it, Ended up working out pretty well. But my damage is a little different from yours.
Old 07-02-2011, 10:49 PM
dgcustomz's Avatar
Were the dust shields installed after the clutch swap? Might have been some road debris that got thrown in there if the covers were not on....
Old 07-03-2011, 01:42 AM
jt76's Avatar
Yes the dust shields were on. Even if they were off, that is kind of a far stretch wouldn't you say?
Old 07-03-2011, 02:13 AM
01ssreda4's Avatar
Looks like it could be a roller bearing off the throw-out bearing. Those do readily tear up and are inside the bellhousing.
Old 07-03-2011, 02:39 AM
jt76's Avatar
the ends of this thing are flat and the sides looked to be "pushed " or "rolled" over from impact (you can kinda tell in the pic that the end was flat at one point) I guess the only way to know for sure what the hell this is, is to pull the trans out
Old 07-03-2011, 04:16 PM
dgcustomz's Avatar
You are asking for help and I gave an opinion. No need to be a dick about it. I build t-56's daily and every car that comes in without the dust covers have all kinds of rocks and pieces of road debris in the bellhousing. So no, I don't think it's a far stretch. Either way, good luck....
