how many bolts in oil pan?
hello,i have a 2001 camaro.i'm trying to lower the oil pan to change the timing chain.i removed the 2 bolts holding on the timing cover,2 longer one's in the pan by the trans,and 5 on each side.loosened the bolts 3/4 of the way out.total of 14 bolts.all with a 10mm socket and speed wrench.well, the pan won't budge. i tried tapping it with a rubber mallot.also tried tapping it with a 2x4 and a small hand mall.is there any other way to get the chain out,without removing the pump?also i do have around 3/4 clearance between the pan and k member.is it something to do with the rivets they install from the factory,that the pan won't budge?car has 60,000 miles.any help is appreciated.thanks
oil pan
thanks,i was only seeing 14 bolts,i see darkman is showing 15.i will double check it again.when i retightened them ,i just used a 1/4 ratchet with little pressure.thanks again for the info and the pictures darkman!
oil pan
i double checked the number of bolts ,and it is 15 with the bolt with the bracket that holds the trans cooler lines on the pass side. i had that one out also,and it won't drop at all.so, i see 6 bolts on the pass side,and 5 bolts on the driver's side,2 for the timing cover,and the 2 long one's in the back.i may just reinstall the stock chain back until i go through the motor in the future.
