5.3L Damaged in Front End Collision
I am new to the LSX style engines, but may be able to get a deal on al 5.3L out of a 2003 Tahoe with heavy damage to the front end. It looks like it hit a telephone pole at high speed. From what I can tell it pulled the rubber engine mount apart on the driver side and pushed it over to the passenger side. The wreck also pushed the front crossmember into the oil pan and cracked it in several places. The front accessory drive system is also busted in several places.
My question is to those with more experience, what areas should I look closely at for damage? Are there any specific areas I should check for cracks as a result of the collision? Any help/suggestions are much appreciated.
Thank You
Thank You
Thank You
Thank You
whole engines sell pretty cheap. imo if it's free scrap it.
