Slow Leak - Clutch?
Slow Leak - Clutch?
Hey,
Still trying to figure out what's causing my clutch pedal to go soft on me.
Yes I've tried bleeding the clutch, no I haven't tried adding Viagra to the reservoir.
Point is, after bleeding the clutch, everything's fine for a couple of shifts...then I lose enough pressure to make it hard to shift. If I pump the clutch a couple of times, I can get another good shift or two before it goes soft again. None of these problems happened before I got the car tuned...so I'm guessing that there's a vacuum leak somewhere. I've identified a very, VERY small fluid leak on the exit valve of my remote bleeder line...in your opinion, do you think that that could that be significant enough to cause this problem?
