05 GTO A4 to A6 tranny swap
I apologize in advance if this has been covered, but I was wondering if it was possible to swap the A4 transmission out of a '05 GTO with the A6 (GM 6L80) transmission from the C6 Corvettes? If so, would you have to shorten or lengthen your driveshaft for the conversion?
I appreciate any positive feedback I can get with this. Yes, I am very new to mechanics; looking to learn as much as I can. Thanks.
No you can't put the corvette one because like mentioned it's in the rear where our differential is.
Also, you can physically fit the A6 from a G8 or Camaro, but the gto computer and wiring harness would not work with it. You would have to do a complete rehaul of the computer and wiring system which could get expensive and tough to do.
