percy split locks
percy split locks
i am doing long tube header install, and 1 stock bolt broke off.
has anyone used these? if so how many heat cycles did it take to make sure they dont backout? thanks for any advice on these.
I put them in then within a day I had lost 4. I had bought the mustang kit which gave me some spares and had to buy more set screws and used locktite on all the set screws.
If I had it to do over again I would use a different system. I don't want to think what they are going to be like to get out.
ARP header studs have never backed out on me. Also you can look into the stage 8 stuff. They have a clip that will not allow them to back out.
http://www.stage8.com/
there are quite a few vendors on there that sell them.
these are what your talking about right?
http://www.summitracing.com/search/P.../?keyword=8900
has anyone used them? i mean i can get stockers, i just don't wanna keep messing around
with retorqing them if i can do it once and be done.
id use the stage 8 , ive never liked the idea of the splits , only takes 1 lapse in memory and youve ruined your head trying to get the bolt out while its spread wide open
ive always used the stock bolts , or the stock studs , never had 1 break in a LS motor , but LT's and old schools i have
