dowel pin from hell
Old 07-12-2011, 01:56 PM
99SSJarhead's Avatar
Default dowel pin from hell
Any tips on separating the trans from the engine? I've got all the bolts out but the driver side dowel pin just doesn't want to let go for the life of me.
Old 07-12-2011, 02:55 PM
heymoej's Avatar
pb blaster.......
pry bar & a ratchet strap from the tail shaft to the rear end..........and ratchet it tight & pry a little & ratchet & pry some more....
(or a chain fall)
good luck!
Old 07-12-2011, 04:23 PM
RARON455's Avatar
A little prying in between the case and the engine, some wiggling and it should let go, Dont be scared to pull it to the side and push back, itll come loose. Make sure you are ready for it.
Old 07-12-2011, 04:39 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Make sure you take all the bolts out of the bellhousing, I can't tell you how many times I have had people forget to pull the bellhousing bolt at 12 o'clock and they try to pry and pry with no success. You should have 8 bolts total removed from the bellhousing and once that is done you can use a big screwdriver or a pry bar to pry side to side to get to break free.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 07-12-2011, 06:22 PM
01ssreda4's Avatar
Yep, double check all the bolts are removed.
Old 07-12-2011, 06:39 PM
1gt2nv's Avatar
I used a air chisel.
Old 07-12-2011, 09:36 PM
senicalj4579's Avatar
I had to wiggle it side to side, use pen oil, and pry it. It was a PITA laying on my back doing that but got er done. Keep at it you will get it.
