anyone here have weld pro star wheels?
i am trying to get some weld pro star wheels for my rear what size should be good with out spacers?have stock rear end...have a 1995 z28 thanks..
I have some. They are 15x8 with the backspacing for stock rear Fbody. I think it is 5.5".
Mine have tires too with moderate life left. They are 275/60/15 Mickey Thompson drag radials.
I have a 5/16" spacer for mine, but its not required. I'm sure you know about that you have to grind your rear calipers for the weld prostars, well the 5/16" spacer just makes it where you don't have to grind as much. But you can choose to not use them, just you have to grind a little more.
Let me know what you think. I'll take $350 for them. They are in excellent condition.
camaro_93zzz@hotmail.com
It don't take long to grind them, but I don't think you should go all the way down. Just use a small spacer.. Just keep grinding and test fitting until they fit. Good luck!
