Comp Cams ls degree kit, ASP pulley
Category: Racing Parts
Price: $125
Location (State): PA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Degree Wheel Included Yes
Degree Wheel Diameter (in) 9 in.
Degree Wheel Material Steel
Degree Wheel Finish White
Number Color Black
Cam Checking Fixture Included Yes
Dial Indicator Included Yes
Piston Stop Included Yes
User Manual Included Yes NOTE - not the best manual, but it isn't hard.
Valve Spring Checking Springs Included No
Wire Degree Pointer Included Yes
Video Included No
Case Included Yes
Case Material Foam/Plastic
Case Finish Black
Quantity Sold as a kit.
Notes Fits all GM Gen III/IV LS V8 engines. This kit contains everything needed for camshaft degreeing when the cylinder heads are off of the engine, an additional piston stop is required for heads-on degreeing.
USED ASP f-body pulley, came loose and no longer has a press fit, WILL NEED KEYED-AS-IS. 50.00 shipped UPS to the 48 states.
