Intake leak or?
Intake leak or?
So I'll be driving my car, and it'll throw codes saying it's running lean in both o2 banks, then after I erase them, my car will start jerking after it sits still and I start moving again say from a redlight or stop sign. Any suggestions on what it might be?
The lean codes can be caused by vacuum leaks anywhere upstream of the motor, contaminated fuel/fuel filter, or low fuel pressure. Other causes, which are less likely since you have codes on both banks, include exhaust leaks upstream of the front o2 sensors or a bad/unbalance fuel injector or injectors.
Sometimes you have to flick the ignition on 2-3 times and take the highest reading - but if it does not hit 50 psi there is a problem. If it is not the fuel filter/fuel (which from what you are saying about the condition of the filter it still could be) then it is a weak fuel pump. Fuel pumps can get weak before they die completely.
The filter is the only thing I can assume is wrong, I just installed a new racetronix fuel pump and harness. So that's not the problem I don't think.
Possible FP Regulator? Did you do the pump, yourself? The regulator is above the fuel pump. Also check the voltage going to the pump itself. Check it right at the pump, if at all possible. Check the ground for it too.
Stock wiring:
-FP Relay is grounded to RF and LR of engine
-FP is grounded to left door sill. (??? no idea why they put it THERE.)
Stock wiring:
I did have an extra ground wire. Im wondering if I find where it should be grounded it might pick up the pressure. It picked up 10 psi just from the fuel filter..
