01 ls6 no throttle response code error p0122
Old 07-22-2011, 11:16 AM
osburn383's Avatar
Default 01 ls6 no throttle response code error p0122
I have a 01 Z06 corvette engine i swapped into my 93 rx7.
It will idle and start fine with the throttle actuator unplugged, but when everything is hooked up it starts and dies with no throttle response.
Im getting error code p0122.
I went and replace the tps sensor but that did not work.
I used a dmm and checked to make sure the tac has power and it does.
Not to sure how to test the pedal sensor and tac to determine if they are bad.
Any help would be much appreciated.
Old 07-22-2011, 03:54 PM
Old Geezer's Avatar
Maybe, start here...??
http://www.gearchatter.com/viewtopic8907.php
Old 07-25-2011, 09:07 AM
osburn383's Avatar
The ecm and harness is all from the 01 c5 zo6.
Its using the stock drive by wire.
I did the factory service manual test on the tps sensor but it doesn't show anything is wrong with it.
I went and double checked my grounds and power source and there all good.
Then i went and did the service manual test for the app, tac, and throttle actuator motor.
All seem to be in spec.
Could it be the reflash i had done on the computer causing the issue.
I can unplug the throttle actuator motor and it will crank and idle at 1500rpm.
I then can rev the motor by pushing the throttle blade open.
Should i be able to rev the motor like that with drive by wire?
Old 07-27-2011, 10:37 AM
osburn383's Avatar
It is now fixed.
My computer was flashed to a camaro and not a corvette, so gotta send it back to the guy to have it reflashed.
Quick Reply: 01 ls6 no throttle response code error p0122
