I've picked my poison...
The time has came. 2 of my close friends are spraying now and I'm getting left in the dust! Time for me to enter the nitrous world.
My mods now.
99 Z/28
- Engine Mods
Free mods w/ !air, !egr
Lid, ls6 intake
LT's with 3in x-pipe and bullets dumped
Frost mail order tune
Tr55's, for now....
- Suspension Mods
UMI- LCA's, sfc's, panhard rod, adjustable torq arm w/ DS loop
BMR- lca relocation brackets
No front or rear sway bar
- Drivetrian mods
Built 4l60e
Circle D 4C converter w/ 32k cooler and gauge
Hughes Flexplate
10-bolt w/ 3.73's and Trick Flow girdle
- Other mods
Wide and Skinnies w/ 275/50/15 ET street radials
Some weight reduction.
So with that out of the way.. It's time for me to reach another goal. And that's to spray this car.
-Some thoughts I have.
HSW? N20 outlet? Plate kit...
Br7ef's of course
Microedge? LNC-002?
Anddddd tune?
Got 2 friends to help with plug reading.
So guys what help can I be gave here? Thanks to all!
Aaron
My mods now.
99 Z/28
- Engine Mods
Lid, ls6 intake
Tr55's, for now....
- Suspension Mods
- Drivetrian mods
Built 4l60e
Hughes Flexplate
- Other mods
Br7ef's of course
Microedge? LNC-002?
Anddddd tune?
Aaron
Guest
Posts: n/a
For what your looking at, I would definitely go plate.
I would start your shopping here:
http://www.nitrousoutlet.com/catalog...5&product=4091
This is complete from Spark plugs to jets. The works.
Br7ef's are going to be the plug of choice for anything sub 200hp in your case. All tho I would probably limit it down to around 150-175hp in your case.
LNC-002 as soon as it comes back on the shelf's. But depending on your shot size and how you personally drive the car, on a bolt on setup you are not gonig to give p too much power by just having the timing pulled.
If you can get the thing to hook, there is no reason our plate setup and your car can not go easy bottom 11's if not faster depending on setup and DA.
So if I was to buy this very kit right now and put it on I "should" be able to run a 100shot and be good right?
Meaning I'd start smaller and work my way up reading plugs til the 100shot.
And later move up to a 150-175shot when the lnc-002 comes out?
What good can I get from a microedge?
Thanks
Thanks
Guest
Posts: n/a
Thanks
Thanks
Correct. Or have frost update the tune with some more timing pulled.
I do not think you need it. Our window switch or progressive and LNC will have you in perfect shape.
