Slow to start??
Old 07-26-2011, 06:48 PM
DOG-TWO's Avatar
Default Slow to start??
My LS1 will not start on the first try, I have to crank it several times, stop, then crank it again sometimes three times before it will start. Replaced fuel filter and that wasn't the problem. Not sure what to check next. Any suggestions...?
Old 07-29-2011, 05:02 PM
lsx24's Avatar
The spark plugs might be shot. Pull'em out give them a look, or just go ahead and throw in another set.
Old 07-29-2011, 05:05 PM
cookba's Avatar
check fuel pressure. check starter, alternator and battery
Old 07-29-2011, 07:39 PM
joecar's Avatar
Replace starter relay and fuel pump relay.
Old 07-29-2011, 08:45 PM
BRIAN P's Avatar
I 2nd the fuel pressure test. then plugs
Old 07-30-2011, 09:18 AM
omarrakeen's Avatar
its the pulser "fuel pressure regulator". its the circular thingy on your fuel rails over the intake. replace it and you will be fine.
Old 08-07-2011, 05:27 PM
DOG-TWO's Avatar
Thanks guys!
