FOR SALE: 2000 Model Corvette LS1 Engine Low Low Miles
Category: Engine - Complete Motors
Price: $2500
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): TX
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
FOR SALE: 2000 model LS1 engine. The engine is in perfect running condition with no problems and came out of my 2000 FRC when it had slightly less than 20,000 miles on it. This engine is complete with the following items:
Intake manifold, throttle body, injectors, Tps sensor
Coil packs, spark plug wires, plugs
Oil pan, front cover, harmonic balancer, front pulley
Exhaust manifolds
Front and rear O2 sensors
New set of knock sensors
Water pump, miscellaneous front accessory mounts
Clutch assembly including flywheel, pressure plate and disc
Engine mounts
Not Included with motor:
Crank sensor
Cam sensor
Oil pressure sensor
Dipstick
Starter
Wiring harnesses and ECU
Intake manifold is currently just set in place and lightly secured to motor as the new knock sensors will need to be installed and hooked up to wiring harness. Water pump and all hardware are currently off motor
and would need to be re-installed.
The motor is completely stock and has never has been apart or had any changes made to it.
Engine is currently mounted in a roll around engine cradle which I will throw in with the engine.
Price $2500.00, Pay Pal Only, Local Pickup ONLY in Dallas Ft.Worth area. I will not ship, so please don't ask.
