Hooker LT Question
Hooker LT Question
If installing Hooker LT's and Hooker Y-pipe, can the stock cats and O2 sensors be kept? Or, will the cats have to be removed and O2 simms used also? Car is a 1999 T/A A4.
Thanks!
Thanks!
SN95 Director
stock cats: why bother, they'll justs choke off the system anyway and you'll need to weld them in the ORY, not worth the time and/or effort.
you'll need to remove the rear o2 sensors and run sims and run extensions for the front o2 sensors.
read the sticky at the top of the page
Thanks for the info My computer at work is too slow and searching around for the info was very painful
So with no cats, and a supercharger, any chance on passing visual and sniffer emission testing?? Would high flow cats solve that problem?
They'll help with any visual inspections as well.
