Does this Evap delete look like it will work
Old 07-28-2011, 07:09 PM
i420tom's Avatar
Default Does this Evap delete look like it will work
Is there anything wrong with this evap delete method? Should this work? Now i cant pump gas!@
Attached Thumbnails Does this Evap delete look like it will work-img00085-20110728-1832.jpg
Old 07-28-2011, 08:49 PM
kmspruill242's Avatar
Just dropped my tank today. I'm building a carb setup and need even less than you do. Anyway I'm not even sure you need to put that breather there. There is already that little hose that came over the side that I'm assuming is the factory breather tube. I don't see why you couldn't plug that port of and be fine. I could be completely wrong though ha.
Old 07-31-2011, 06:57 PM
Sc0tt30's Avatar
When i did the evap delete on my 97 i left part of the line coming out of the tank there that went to the evap but put a sock filter over it to keep anything out of the line and so there was still a relief there if it was needed. From what i read you still need that line so the tank can vent but what i read could be wrong and you could just plug it.
Old 10-31-2011, 09:39 AM
i420tom's Avatar
I have the evap delete setup as the pic in the first post shows. However i cannot pump gas!!! What should i change or check???? please hurry lol i need gas!
Old 10-31-2011, 10:24 AM
95FbFormula's Avatar
When pumping you need somewere for air to escape that breather may be to much can you pump at all or does it pump and little then click off
Old 10-31-2011, 10:55 AM
i420tom's Avatar
it clicks immediatly as soon as i squeeze.... if i let the gas just barely trickle outta the pump into the tank it does work. but it took me 10 minutes to get 5 gallons in this morning, and when i tried to fill it with my portable gas can it spilled gas everywhere as it too would only let the gas in very very slowly. I will try to pop the breather off and see if that fixes it.
Old 11-01-2011, 07:28 PM
i420tom's Avatar
The breather was too much restriction! I removed it and left the open hose up by the filler neck and viola! I can now pump gas as fast as the pump can dish it out.. Awesome!!!!!!!!!! Thanks guys
Quick Reply: Does this Evap delete look like it will work
