00 ws6 drag radial transam roller stock suspension
Year: 2000
Make: Pontiac
Model: Trans Am
Price: $18500
Mileage: 35780
Private or Dealer Listing: Private Listing
Location (State): LA
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
FRONT SUSPENSION ARE TUBULAR K MEMBER POWER COATED NEEDS MOTOR PLATE ARE ADJUSTABLE LOWER CONTROL ARMS RACE CRAFT TUBULAR UPPER CONTROL ARMS RACE CRAFT MANUAL STEERING RACK WITH BUMP STEER KIT QA1 FRONT SHOCKS SINGLE ADJUSTABLE 275 DRAG FRONT SPRINGS
BRAKES WILWOOD MANUAL MASTER CLY WILWOOD BRADIED BRAKE LINES FRONT AND REAR STOCK BRAKES FRONT AND REAR ADJUSTABLE PROPORTIONING VALVE AND LINE LOCK
REAR SUSPENSION MOSER 9 INCH WITH 35 SPLINE AXLES AND 410 GEAR WITH DETROIT LOCKER WITH LONG STUDS FRONT AND REAR. ALL REAR SUSPENSION IS BMR ADJUSTABLE LOWER CONTROL ARMS,PANDHARD ROD,SWAY BAR,TH350 CROSS MEMBER WITH TORQUE ARM RELOCATION KIT BMR DRIVE SHAFT LOOP ADJUSTABLE TORQUE ARM RAMOND TECHNOLGY REAR SHOCKS ADJUSTABLE COMPETION ENGINEERING
FUEL SYSTEM SPEED INK CUSTOM ALUM FUEL TANK WITH REAR SUMP IN STOCK LOCATION ALL BRAIDED LINES WITH RETURN BACK TO TANK FUEL PUMP SUPER HIGH VOLUME CAN BE USED FOR EFI OR CARB
BATTERY OPTIMA YELLOW TOP BILLET BATTERY BOX IN REAR WITH FLAMING RIVER BATTERY DISCONNECT SWITCH WITH HOT SHOT RELAY BUMP SWITCH UNDER HOOD WITH HEAVY DUTY BATTERY CABLES
IGNITION ALL IGNITION IS MSD DIGITAL 6 PLUS BOX WITH TIMING CONTROLER HIGH POWER HVC COIL CUSTOM BUILD 8 CIRCUIT RELAY PANEL WITH CUSTOM 8 CIRCUIT SWITCH PANEL TOTAL CAR HAS BEEN REWIRED ALL GAUGES ARE SLIVER FACE AUTO METER OIL,TEMP,VOLTS,OIL TEMP,VAC AND BOOST WITH GAS GAUGE TO WORK WITH TANK PLAY BACK TACH WITH SHIFT LIGHT CHROME MOLY 6 POINT BOLT IN ROLL BAR AUTO METER PRO MIN WARRING LIGHTS FOR OIL AND TEMP B&M PRO RACHET SHIFTER ADJUSTABLE FOR ALL TRANS COMBOS
RIMS RACE STARS REAR 15X10 WITH 7.50 BACK SPACE FRONT 15X3.50
TIRES ARE MICKY THOMPSON REAR 275 DRAG RADIALS FRONT 26X7.50 BY 15
HOOD VFN BOLT ON OUTLAW 8 INCH UNDER PAINTED TO MATCH TOP
MOTOR PARTS SMALL BLOCK CHEVY PARTS TO BUILD A 408 EAGLE CRANK,EAGLE H BEAM RODS WITH 2000 ARP CAP SCREWS SRP COATED FORGED PISTONS BILLET MAIN CAPS WITH ALL ARP STUDS CRS STARTER BILLET TIMING COVER WITH TRUE ROLLER CHAIN ELEC WATER PUMP WITH RED WATER NECK LUNATI ROLLER ROCKERS WITH STUD GIRDLES HOLLEY RACE 1050 DOMINATOR WITH ATI BLANCER COMP CAM 630 660 ATI 8 INCH 4500 RACE TH350 NEW NEEDS ULTRA BELL TO COMPLETE ALSO WILL THROW IN CORSA CAT BACK FOR SOMEONE THAT WANTS TO PUT A LS1 BACK IN WITH 3 INCH Y PIPE STEREO SYSTEM IS NOT IN THE DEAL UNLESS WE WORK THAT OUT TO MUCH TO LIST WITH THIS CAR THIS IS NOT A REG TRANSAM THIS IS A SERIOUS PIECE WILL NOT GIVE IT AWAY PICS DO THIS CAR NO JUSTICE NEED TO SEE IN PERSON SERIOUS INQ ONLY THANKS NEED MORE INFO CALL BOBBY 985-651-0292
