Can dbw be converted to cable driven?
I'm currently doing a Ls6 swap in my 94 Impala ss but the engine harness I purchased is from a 6.0L with a DBW setup I wanted to know if I can convert it to a cable driven throttle body and if so how much work will it be to do thanks.....
2003 was the last year the stepper motor for the IAC was installed in the PCM. Your PCM will have to have the stepper motor to be able to convert. You can go to this website to find out how to determine if in fact yours has it or not.
http://lt1swap.com/cable_conversion.htm
I think you will find this website is very useful if you want to convert it over.
Maybe.....
http://www.lt1swap.com/cable_conversion.htm
