Wheel help
Old 08-06-2011, 09:37 PM
fastredlt1's Avatar
Default Wheel help
I have set of weld prostar wheels with M/T ET street tires. The tire size is 275/60/15 and the rims have a 7.5 BS witch i was told is right for my 95 TA. I went to put the wheels on and the studs on the axle are way to short to put lugs on. Anyone have any advice????
Old 08-07-2011, 08:25 AM
bigj2717's Avatar
The backspacing depends on the width of the rim. You need a 15X10 with 7.5 bs or 15X8 with 5.5 bs. As for the studs the stock ones will be short, you can either run them or do the safe thing and install some longer wheel studs.
Old 08-08-2011, 04:59 AM
Captain Double Post
BOBS99SS's Avatar
yeah you will need longer studs for sure, i had to get longer studs,spacers,and grind my calipers ,
Old 08-08-2011, 09:32 AM
wheelczar's Avatar
Default Prostar / Studs
The lug nuts for these wheels are 1.310 inches long and will reach to about 1/4 of an inch to the bottom of the stud. I would make sure you have the right lug nuts. You should not need longer studs.
Old 08-10-2011, 11:18 PM
fastredlt1's Avatar
Default wheel help
So I checked and the wheels are 15in by 10 w, with 7.5BS. So do I need longer studs or is there a special kind of lug nut???? Anyone have pics? Thanks for the help.
Old 08-11-2011, 03:04 PM
bigj2717's Avatar
Yes you need longer studs. For lugnuts you need extended shank lugs
Old 08-11-2011, 05:31 PM
jjordan's Avatar
Listen to WheelCzar, the Prostar is designed for a shank style lug that goes down inside the wheel and actually squeezes the wheel when tight. The lug does NOT stick out of the wheel, the lug nut goes into the wheel to contact the stud. If you are going to drag the car at the strip, do yourself a favor and get an open end shank style lug. The tech guy can look in the end and see that you have a full lug engagment, otherwise he might make you pull a lug off in tech so he can see the same thing. Get the 1.310 shank length.
