Notices
V6 swap list the parts I need?
Old 08-07-2011, 12:56 PM
redcamaro4140's Avatar
Default V6 swap list the parts I need?
Here my list I need,
Intake,fuel rails,injectors, water pump , alternator brkt, alternator,powersteering pump and mounting brkt,cam sensor,crank sensor, temp sensor,i have a stock throttle body,maf sensor,air lid, radiator and cooling fans,engine bay harness and computer,1999 or newer 1998 computers suck.
oil pressure sensor as well, and map sensor.
2 knock sensors as well.Starter, dipstick tube and dipstick,exhaust manifolds or headers
That should handle your engine bay, there are 2 harnesses you will need in the engine bay.
The one for the computer, and the one which has all of your fuses under the hood.will need a a 4l60 e for the ls1 with a bell housing as well.
Old 08-07-2011, 05:19 PM
95 mystic ls's Avatar
You may find it easier to find a wrecked car. That way you have everything you need. It made my swap go easy, I didn't have to track down individual parts.
Old 08-07-2011, 06:39 PM
andrew69_04's Avatar
sent you a pm. i've got everything and im fairly close to your location
