Need a Part Number for O-ring
I seemed to have lost my clutch line O-ring that goes into the master cylinder when I had my clutch line drilled.
Does anyone know a part number or a place you can source it without buying a new line? Dealer was no help.
This is for a F-body clutch line.
I don't think the O-ring can be purchased by itself. It comes with the master and the line. I don't believe that you can even get just the line.
If your not in a huge hurry I three old masters in the garage that I can pull an o-ring off of and send to you.
I you need it quicker and have a set of dial calipers you might be able to measure the fitting and try to get a comparable sized one from the parts store.
You can get the line, since I bought a new one originally.
I ended up getting this fitting, since it comes with the correct o-ring.
http://www.speedwaymotors.com/LS1-an...ing,25017.html
