tsp headers and ory also which cam for the street
Hello I was wondering if any one used the tsp headers and ory. It's a ls1 trans am 2000 I have a magnaflow ext and a slp lid. I have a ls7 clutch and I would like a cam don't really know what to get. I want a street cam with a good lope and makes good power. I also need springs probably push rods and lifters. The car has 121000 miles on it should I look into heads too.
All I know are bikes and those cans you go to hrc they say buy thing with this spring and this is what the squish you should have and set the cams between this degree and that and your off.
With that amout of mileage definitely add lifters, lifter trays, oil pump, an a timing chain to your swap(cheap insurance). With that being said the heads would be off(due to lifters) so it would be a good time to swap them or have work done to them. call EPS to get help on a good street cam.
