Moser 12 bolt need help removing axles
need help removing axles! i have an auburn differential if that makes a difference with anything. i have removed the 4 bolts holding on the axles. and no i dont have the tcs ring
http://www.chevelles.com/forums/showthread.php?t=350905
been going off of this write up and i removed the pinion shaft lock bolt and pinion shaft. im having trouble moving the axle in it remove the c-clips. its not budging at all!
on my moser 12 bolt, i have a clip but it looks more like a bearing, but at the end of the axle and all i had to do was use a pry bar to break it lose and it pulled right out
yeah i resolved it. my moser doesnt have c clips and yes your right, all i had to do was pry out the axle basically. but i didnt take off the backing plates because i thought it had nothing to do with it. dumb me.
