1997 Trans Am WS6 Ram Air 383 for sale
Year: 1997
Make: Pontiac
Model: Trans Am
Price: $12000
Mileage: 110000
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Green
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
This car has a ton of mods including a 383 Stroker engine built by Golen. The engine has around 30k miles on it and the body has 110k. This car has every mod imaginable and just got back from being rebuilt with a new custom cam and tune. It is a rare green color with tan leather interior. Its a 6 spd car with t-tops that don't leak. The exterior is in mint condition with original WS6 polished wheels. Here is what I have so far...
Engine:
383 CI built by Golen Engine Services
4 Bolt Main
Eagle Forged Crank
Scat Forged I-Beam Rods
SRP Forged Pistons
Power Moly Ring Set
Crane Cams Custom Hydraulic Roller Cam 250/258 .555/.558 114
Comp Cams Lifters set 875-16
Heads:
LE2 CNC Ported Heads
Ferrea Valves
Comp Cams 987 Springs
Comp Cams 1.52 Rockers
Comp Hardened Push Rods
Induction:
Port Matched Intake Manifold
AS&M 58mm Billet Throttle Body
Ported MAF
Ram Air Box with K&N Filter
Exhaust:
Kooks Stainless Steel Long Tubes
Kooks Stainless Steel Off Road Y-Pipe with Wideband Bungs
Borla Stainless Steel Adjustable Catback
Suspension:
Kenny Brown Double Diamond Sub Frame Connectors
BMR Panhard Rod
BMR Lower Control Arms
Eibach Sportline lowering springs
Ignition:
Brand New MSD OptiSpark
MSD Plug Wires
MSD Blaster Coil
MSD 6AL
NGK TR55 Plugs
Stereo:
Alpine CDA-9857
Alpine MRP F250 AMP
Alpine 6.5 Type S with Component (Front)
Alpine 6.5 Type S (Back Seats)
Alpine 4 Type with Component (Rear)
Cooling:
Hyper Tech Thermostat
CSR Electric Water Pump
Wheels and Tires:
Nexen 245/40/17 (Front)
Toyo TQ Drag Radials 275/40/17 (Rear)
Stock 17X9 Polished WS6 Wheels (Stripped and Re-Polished with NO CLEAR COAT)
Fuel:
32lb Racetronix Injectors
Walbro 255 Fuel Pump
Aeromotive Fuel Pressure Regulator
Computer:
Tuning done by DynoJet Performance 390HP 380TQ to the wheels
Transmission:
Mcleod Twin Disk Clutch
Hurst Billet Plus Shifter
03-04 Cobra Shift ****
Thanks!!
