Best way to go about changing sparkplugs?
Old 08-10-2011, 06:46 PM
BlackDemonSS's Avatar
Default Best way to go about changing sparkplugs?
so this is the first time im going to change my plugs? I have a 99 SS Camaro and wanted to know if there are any tips to make this experience less painful?
Old 08-10-2011, 06:48 PM
AwsmGy's Avatar
You can get all the from top. For some people it's easier to get the ones in the back from under the car.
Old 08-10-2011, 07:56 PM
JohnS Z28's Avatar
Pretty sure theres an install university about this
Old 08-10-2011, 08:25 PM
xxrillixx's Avatar
^ probably.
i like to remove the passangers side coil pack... makes it SO much easier to get to everything over there. Also feel free to remove the smog stuff (if youve got it) from the headers (2 10mm bolts).
When removing the wires, remember to pull the boots... not the wires.
When installing the wires, make sure you hear 2 distinct clicks. If you hear 1, its not on all the way. Make sure you keep them as far away as you can from the headers.
