LH8 Oil Pan machined for Bypass Valve
We are now offering the LH8/Hummer oil pan machined for the bypass valve used on the Variable Valve Timing and Active Fuel Management (Displacement on Demand) engines. The process to make sure that everything is square and properly seals, includes using a CNC to face the surface, drill the hole & cut the threads. Our oil pan kit includes the oil pan, gasket, bolts, windage tray, pickup tube, dipstick & dipstick tube all for $249 plus shipping. The pictures shows the pan with the bypass valve installed, our pan kit does not include the bypass valve (we do sell the bypass valve separately).
hey i bought a pair od 1 3/4 stepped to 1 7/8 long tube headers for my s10 a long time ago when yal first started making them needless to say they didnt fit after after no help from customer service i gave up on them i also purchased yals install kit at the time whats the status of the headers now has any improvements been made for better fitment
Jeff
I cant tell them apart 2008-2009, and 2010-2012 minus the built in relief added to the oil pan, on the later casting.
What's the reason for the relief anyway? Higher volume pump for VVT or AFM, and so it as a relief when not in that mode? I plan on deleting the VVT on my motor, I don't no weather to plug the relief, and run a standard oil pump?
