How to adjust parking brake on 95z m6?
I put a new rear end in my car and everything is hooked up. Tried to pull the ebrake 3 times and it didn't work. Do
I have to get under the car to do it. Every time I start the car the abs inapproble light comes on. Can I get some help. The brakes work great
ebrake adjustment is a thumb wheel found behind each rotor, just take the wheels and rotors off and you'll see them
and did you plug in the abs sensor in the rear? 3 channel (no tcs) or 4 channel (tcs)?
Isn't there a cable from the ebrake handle the runs under the car, and meets the cable for the e-brake itself? This was how it was on my s-10. The juncture where the handle cable meets the brake cable was adjustable with two bolts, I believe.
I have yet to look at my car, but it could use a little adjustment as well.
When I pull up the ebarke, only the last 1-2 clicks will keep the car held. Anything less and the car can still roll if on a down hill. I always leave it in 1st too, so I tend not to worry about it.
If F-body's have this same 'cable juncture' that I mentioned above, I would venture to guess it's below the rear seats.
