a few noob tuning questions
im using tunercats
first is, what should my knock settings be at to eliminate false knock?
the second is, my extended spark table says 32 degrees at wot range. but when i datalog, it says 36 degrees. where is the other 4 comming from? i cant find it anywhere
I'm guessing since you are running a LTx based engine. Most people on here are LS people. There may not be anyone that's familiar with that software. I know you are frustrated but don't get shitty when someone doesn't answer your question on a weekend on software that nobody probably uses.
