ecu switched power/ecu ground
hey all, having a few drawbacks on my 350z. got the triple pump setup hooked up and i need to find the switched power and switched ground wires from the ls ecu. i recall reading that the pink wire is switched power but id rather be 100% sure so any insight to the switch power and ground off the ecu would be great. thanks!
Basically any solid pink wire is switched power, black w/ white stripe is ground, orange is constant power.
What year is the PCM? Take a look at the pinouts in this thread if you want to be sure: https://ls1tech.com/forums/conversio...swap-faqs.html
