Switching from 7.4 to 7.425 pushrod help
Old 08-14-2011, 03:32 PM
Big Red Z28's Avatar
Default Switching from 7.4 to 7.425 pushrod help
Switching pushrods from 7.40 to 7.425 I currently have the 1.7 yella terra rockers. If i do one set at a time will i have any problems? Any info before i get in a situation i cant fix would be appreciated, Thanks.
Old 08-15-2011, 12:56 AM
LilJayV10's Avatar
Do you know if the longer push rods will effect the wipe pattern on the YT's?
Old 08-15-2011, 01:17 AM
99Bluz28's Avatar
The push-rods length shouldn't effect the wipe pattern only the preload, shims are used to set the wipe pattern with the YT non-adjustable rockers.
FYI, if you change/re-adjust the wipe pattern with different shim heights it will change your pre-load.
Old 08-15-2011, 01:22 AM
LilJayV10's Avatar
That's what I was wondering if the two were independent or not to each other.
Old 08-15-2011, 05:02 AM
vettenuts's Avatar
With the Yella Terra's, start with cylinder #1 and install the rocker pair at TDC. Rotate the crank 90 degrees and do the second cylinder in firing order. Continue until all the rocker pairs are installed.
