LM1 wideband with DELTEQ rpm help
I have an LM1 wideband with rpm converter cable with inductive pick up cable. I cannot get the correct rpms to work. I have tried auto configuration and used the programer software to tell the LM1 its a waste spark ignition.
Any help would be appreciated.
Nope, its not what I want to hear. But, since i have it, I need to attempt something here to get rpms with the AFR. Someone had used a tach adapter.
Delteq and LM1...not working to well for me.
I can run TTS Datamaster at the same time, then look at the logs side by side. Not very accurate, but its the best I can do until this thing can work./
