Ls1-ls6?
Ls1-ls6?
how much would it cost...what does it need and how much actual work is needed to get the engine to be the LS6...is the ls5 the same size or is it a 427?....if its smaller would it just be better to go for the 427....ima lil behind on posts so i fugure catch up now lol...
some1 said in that one mustang dyno forum that it would be 1300....but i dont understand whats needed for it and how much work would be involved and everythign
LS6 cams are usually around 400 or so with springs and stuff....i dunno how much for the heads exactly...
SN95 Director
why would you have your standards so low? for the cost to overhaul your ls1 to ls6 spec you can pick up a TEA/FMS h/c combo and be walking ls6's all day long
paceparts sells a conversion kit ranging from 1500-2500 depending on year and if you want ported heads.
and there is no ls5. theres lt1, ls1, ls6, ls2, and ls7.
and deepblue since he has an 02 he already has a 25% chance of having an ls6 block standard.
There's an lt5 but no ls5
and jrp i see you becoming a newbie mod in the near future...goodluck
SN95 Director
32 valve DOHC
and thanks, but the way things are now i'll just continue being a regular member who helps out
also technically there IS an LS5 but i dont think you want to put one in a fourth gen f-body....it was the lo-po version of the 454 big block that came in chevelles and el caminos and such...
i dindt mean to put LS5 that was a typo...sry guys...i meant LS6....whats the size on the LS6 is it the same as the ls1...whcih i believee is 346 ci...or is it bigger?
forget both of them.....just do a good set of heads and a good cam and you'll eat LS6s for breakfast and have a lot more money leftover than if you went the 427 route. ask around some of the head/cam guys will point you in the right direction.
Originally Posted by jaberwaki
the word on the street is that ls7 will = 500/500 hp/tq!!!!
emissions legal ...
good gugamuga!!!
emissions legal ...
good gugamuga!!!
LS7, which is only a logical conclusion, it won't
be out until 2006 model year at earliest.
Don't forget that some inside sources also
say that depending on Dodge's response to the
500hp C6 with the Viper, an ultimate superC6 may
drop that will "blow away all know supercars"
and cost over 100 grand. I think either way GM
needs a exotic to match both the Viper and Ford GT40
