Vendor for LS6 valve springs.
Internet Mechanic
Just throwing it out there. You could consider a aftermarket kit. Nothing too crazy but if your doing the job, might as well go a little better. Most times if you up on the cam its less work down the road. Also most times the added benefit of valve train control and spring pressue helps.
Thanks guys. I'm on a tight budget for this. So I'm sticking to strong and reliable for a decent price. I did manage to track down a set from a fellow member. Thanks again guys!
