GTO MN12 in 01 camaro
Old 08-19-2011, 09:58 AM
01CaMMMaro's Avatar
Default GTO MN12 in 01 camaro
I'm about to drop in a LS2/MN12 T56 from a 05 GTO into my little v6 01 camaro. Had a couple questions about the hydraulics. Can I use the the FBody master cylinder from an 02 TA on this? The GTO master has a much longer pedal shaft than the fbody master. If I can use the fbody master, can I use the MN12 slave cylinder? It looks identical as far as the connector for the master, just want to verify though before i buy anything.
Old 08-19-2011, 11:52 AM
SNLPerformance's Avatar
You can use the F-body master, but it's quick disconnect fitting won't mate up to the GTO slave. Feel free to call me and we can get you what you need. Chris, 817-750-2000
Old 08-19-2011, 12:14 PM
01CaMMMaro's Avatar
Ok thanks, so I just need an fbody slave and I'll be good? I already have one if so.
Old 08-19-2011, 10:28 PM
01CaMMMaro's Avatar
Ttt...
Old 08-21-2011, 11:12 PM
nmass399's Avatar
You putting the trans behind the v6 or putting the ls2 in there also? You can us the f-body master from an 02 ta, i would buy new oem slave cylinder f-body part number. Your gonna need a shifter assembly for a f-body t56.
Old 08-21-2011, 11:38 PM
jmd
jmd's Avatar
And the F-body shifter needs the F-body offset shifter block.
https://ls1tech.com/forums/11689701-post2.html
Old 08-21-2011, 11:48 PM
nmass399's Avatar
Forgot about that. Not sure where exactly to get one either.
Old 08-22-2011, 11:11 PM
flintwrench69's Avatar
I would be suprized if a T56 bolts up to a 3800, its a different bolt pattern than a Chevy.
Quick Reply: GTO MN12 in 01 camaro
