Clutch Switch Input Circuit....help!
Old 08-20-2011, 04:20 PM
HorsePOWA's Avatar
Default Clutch Switch Input Circuit....help!
2000 firebird formula - service engine soon like is on, ran a scanner and it said clutch switch input circuit. i did just recently replace my stock clutch MC with the tick adj MC, could this have anything to do with it?
Old 08-20-2011, 04:23 PM
therealcreeper's Avatar
LS1Tech 10 Year
yes, with the tick the pedal doesn't come up as far and compress the switch fully
go under and just push the switch further in until it makes contact again
Old 08-21-2011, 01:23 PM
HorsePOWA's Avatar
oh ok...sweet
Old 08-21-2011, 07:40 PM
BigBadVoodoo Daddy's Avatar
not to hyjack ur thread bro but I am having the same problem....I just recently installed a MC from autozone and my SES light came on as well with the same code......clutch switch input. My question is when you say go under where do you mean? Under the car where the MC plugs into the slave or where the MC connect to the pedal? Thanks
Old 08-21-2011, 11:58 PM
LS1Tech 10 Year
down by the pedals themselves, take off the bottom interior panel so you can get a better view, there's a switch at the bottom and the top of clutch pedal
Old 08-22-2011, 12:10 AM
zacht's Avatar
i recently have this hanging out...broken clip...
what problems will i have without it hooked up? or contacting the pedal?
i still have to push in the clutch to start the car too...
Quick Reply: Clutch Switch Input Circuit....help!
