Anybody have the washer size that separates the top spring perch from the shock body? I forgot it and dont think I have it any more! I'm probably going to use the lower perch and might as well put those back on, lol.
The spec is 54mm OD, 10.4mm ID. I don't know how much luck you will have finding it from anyone but Koni since the difference between the inner and outer diameter is so extreme.
Thanks! I might end up making some, or looking for some at work.
