lq9 cam question
If you mill the heads like .030 or slap on some 243s to get the compression
up to 10.5-10.8 : 1 range a GOOD tuner could get the EPS 222/226 cam to
idle stock smooth...doubt you'll make 500 flywheel horse unless you put on
some TrickFlow or AirFlowResearch heads...Maybe have Advanced Inductions
at least CNC the 317 castings for half the cost of aftermarket heads
thanks for the info thats helps a lot we are try to build a sleeper motor where still doing some research on what we want to do for heads if we want to rebuild the stock heads or go with somthing different what about the z06 cam is that any good
do you have the 6.0 already ?if so what are the head casting numbers ?whats your budget?go with a EPS cam ,talk to Geoff at EPS and he can help you figure out a good motor combination and spec a cam for you.you will need a ls6 intake and a ported TB,and bigger injectors.get the cam after the heads are done,porting,milling,valve job ,and flowed.
yes we do have the motor the cast number are 317 we want to stay under $7000 with mounting the motor in the car what are some other things that we might have to do with the motor what the motor we be doing is street driver and drag racing a little
LS1TECH & Trucks Sponsor
If I was you I would go to a 243 casting head and have it ported. This way you can achieve the desired compression ratio without killing a bunch of piston to valve clearance. You can look into a little larger of a camshaft which will make it much easier to make the desired hp. A set of ported 243s and a 233/239 camshaft would easily yield 510-530 at the crank as long as the proper bolt ons are on the motor.
