Quick question about cleaning heads/cylinders
Old 08-26-2011, 01:34 PM
pairof69s's Avatar
Default Quick question about cleaning heads/cylinders
I recently pulled the heads off my LQ9 to clean them up, I sprayed some degreaser in the cylinders then dumped it out....everything cleaned up fine but was wondering if degreaser is a little harsh for the cylinders if so what should I use, brake parts cleaner?
Old 08-26-2011, 01:51 PM
raven154's Avatar
Those are both harsh with the brake cleaner even more so. Just hose it out with the parts cleaner and make sure every thing has a good coat of oil before you spin the engine over.
Old 08-26-2011, 02:10 PM
Blwn_by_Twins's Avatar
Old 08-26-2011, 02:21 PM
pairof69s's Avatar
by parts cleaner you mean brake parts cleaner?......I probably sound like a moron
Old 08-27-2011, 07:42 PM
chrisfrost's Avatar
He most likely means solvent , the stuff they use in a parts washers , auto parts suppliers will know what you mean if you say engine solvent or solvent for parts washers . You can also use warm water and dish detergent like dawn , but You want to dry it right away and yes a light clean coat of oil after any method You use .
Old 08-27-2011, 07:51 PM
raven154's Avatar
Either one really. Wont really matter as long as you give it an oil bath afterwards.
Old 08-27-2011, 08:25 PM
mbaker3's Avatar
Sea Foam motor treatment, as long as you dump it and oil it after. I have soaked pistons in a plastic tub, after pulling them out, with Sea Foam and they cleaned up great.
Old 08-28-2011, 11:59 AM
pairof69s's Avatar
damn i'm in Lakeland too
Old 08-28-2011, 12:05 PM
01ssreda4's Avatar
Take them to the machine shop for cleanup and acid bath. Come out looking brand new
Old 08-28-2011, 07:12 PM
mbaker3's Avatar
Well,..........drive over to Discount Auto on South Florida Ave. and buy you a couple of cans and clean them pistons and heads!
Old 08-28-2011, 07:34 PM
pairof69s's Avatar
thats the plan.....are there any precautions to having aluminum heads hot tanked...?
Old 08-28-2011, 09:28 PM
01ssreda4's Avatar
Mine always come out looking fantastic......
Old 08-29-2011, 04:44 PM
mbaker3's Avatar
I guess I didn't read your first post good enough, I didn't realize that you were tore all the way down to just the block. Take it to Owensby's on Pear Street in Lakeland. They will hot tank it and the heads. I had them do a SBC recently. They checked for cracks and installed cam bearings and they did everything for about $150.
Old 08-29-2011, 05:05 PM
pairof69s's Avatar
yeah...didn't realize Owenby's was still there?
Old 08-30-2011, 05:57 PM
mbaker3's Avatar
it's an auto parts store now but they still have their machine shop in the back................ unless they just closed it!
