speedometer is broken
Old 08-26-2011, 05:23 PM
Rednaxela's Avatar
Default speedometer is broken
hello all:
I've taken my car to two of my mechanics - neither one knows how the fix the problem.
my 2002 camaro's speedometer is broken. it only moves to 1/3 of my actual speed (if im going 60 it will show 20)
I bought this car with 4.10 gears in it - at that time, the tires were 245s. I think the speedometer started to read inaccurately after i bought new tires (275s) - can this be a source of the problem?
on ls1tech i hear the solution for my problem is to recalibrate the pcm. What type of shop would I look for to do this?
and lastly - is there any chance of any other reason or diagnosis for why my speedometer would be reading in such a strange way.
Thanks.
Old 08-26-2011, 10:04 PM
RARON455's Avatar
The gear change could definately cause an issue like this, especially if the car was a 2.73 or something like that. I could also be a bad VSS. If you want to have your PCM flashed, I would contact FROST on this site, he can flash your ECM and put in some goodies to make it run a lil better also.
Old 08-29-2011, 01:22 AM
HumpDay's Avatar
could just be the pcm needs a retune
