Wich roller would be the best ...no shaft mount
Old 08-28-2011, 08:06 PM
always faster's Avatar
Default Wich roller would be the best ...no shaft mount
I ve just finished my new build (383 stroker with 240/244 .608/.612 ,113 lsa) and it only missing a set of roller rocker (in stock ratio).
What would be the best one to use that would be reliable, that would fit stock valve cover and would not have any kind of clearance issue with the casting of the heads...using some PRC LS6 2.5 CNC wich are either 243 or 799 casting.
Thanks :thumbs:
Old 08-28-2011, 09:00 PM
raven154's Avatar
I haven't had any issues with my Crane gold rollers.
Old 08-28-2011, 09:05 PM
Darkman's Avatar
Do those fit under the stock valve cover without spacers/mods?
Old 08-28-2011, 09:17 PM
I should be more precise:
I was running some HS on my stock 243 and they where fine but now with the PRC head a couple of them rub the casting of the head and 2 of them are nearly stuck there.I dont wanna buy some yella terra or other brand if they are gonnas have some clearance issue.
Does the crane are adjustable or non adjustable?Would like some NA .
Old 08-28-2011, 10:06 PM
raven154's Avatar
The cranes fit perfect on stock 243 heads with no spacers and they are adjustable. I can't speak for the PRC heads but I have a spare if you want to test fit one. I don't have any extra studs though.
