Will G8 GT 19" wheels fit 99 SS ?
Old 08-30-2011, 07:57 AM
99SSragtop's Avatar
Default Will G8 GT 19" wheels fit 99 SS ?
Just wondering if there are any clearance issues ?
Thanks
Old 08-30-2011, 09:08 AM
QIK E's Avatar
Weird.... I was just wondering the same thing
Old 08-30-2011, 05:48 PM
Double-aught_Z/28's Avatar
Not with out modification. Remember the G8, like the '04-'06 GTO, is a Holden underneath; so the bolt pattern is metric.
G8= 5x120mm 4th Gen= 5x4.75" =5x120.65mm
It's close enough they can be made to fit but it'll take some grinding or some adapters.
Old 08-30-2011, 09:56 PM
QIK E's Avatar
Although not ideal, 5x120mm wheels will fit without adapters. It's .65mm..it's the offset/width that will make these specific wheels not fit. I think they have higher offset which will make the back of the wheel possibly rub or not fit....If that's the case, they would need a spacer and probably a big one. I think they are pretty much the Cadillac ct-v 19s
Old 08-31-2011, 07:35 AM
99SSragtop's Avatar
Thanks
Old 08-31-2011, 07:48 AM
elmarro's Avatar
I have a G8 & a Ws6 they fit fine but don't like the look but it might look a little different on a Camaro..
Old 08-31-2011, 12:13 PM
QIK E's Avatar
Can you post a pic? So does that mean any G8 wheels will fit? I'm interested in aftermarket wheels that are made for g8s...Do f-bodys and g8/gtos have the same offsets? Any clearance issues?
Quick Reply: Will G8 GT 19" wheels fit 99 SS ?
