Automatic Transmission - 4l80e intermediate shaft
hawkls7
08-30-2011, 05:14 PM
for high hp builds i was advised to use a solid intermediate shaft . my conserns are (lube ) . By having a solid shaft does this restrict lube to the
output shaft bearing ? , also does this restrict lube to the rear planetary ?
slow67
08-30-2011, 07:03 PM
http://ls1tech.com/forums/automatic-transmission/1453411-4l80e-locks-reverse-no-4th.html
Looks like you should be running a solid shaft anyway?
hawkls7
08-31-2011, 04:50 PM
if i should be running a solid one , is it for strength or lube ?
slow67
08-31-2011, 10:06 PM
For sure lube, and if your over 1000hp for strength also.
hawkls7
09-01-2011, 04:38 AM
Thanks . Hopefully my planetaries will survive this rebuild, and not fail due to
Previous lube issues .
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
