Is my stock diff on its last legs??
I have a 2000 TA WS6, A4.
It is doing the ratcheting thing when you go slow or slow down. It is becoming pretty obvious now inside the car.
It has also started, over the past couple months, started a new behavior. It seems to want "Spool up" or has slack at times. Then when you hit the gas it takes a second to wind up and then makes a clunk and works fine. I notice it most when I am slowing down or am cruising slowly when the drivetrain is not under load then hit the gas.
This sound like the diff? The Tranny is behaving well, no slipping that i can detect and the noises seem to come from the back of the car.
I thought the housing might be loose so I replaced the LCA's, panhard with UMI stuff. that took the physical clunks out from the bad bushings. The Torque arm is solid.
well not to hijack,but im concerned about mine as well.....except i have clunking and banging at low speeds........when i pull into a parking space ill hear a clucnk and like my axle is sliding bck in forth...then when i back out of the space, when i start moving it will clunk once, then when i put it in 1st and straiten out, it will clunk again......does yours do this?
